where to run temp gauge line....
RE: where to run temp gauge line....
After you get your answer, I'd like to know how difficult it is to hook up a three-gauge cluster that tells temp, oil pressure, and volts. But only after you get your answer.
up to the front of the lower intake, where the old temp sender is. Any hanes manual will tell you where it is. You just take the old one out and put the new one in. Mechanical gauges are definatly the way to go.
on the foxes there is a sensor right by the IAT sensor on the lower intake manifold, but your SN-95 may be different.
ORIGINAL: seanjohncombs001
I bought a autometer temperature gauge for my car, and i was wondering where you run the line to on the block, its a liquid line. Anyone have ideas?
i have another question, i was wondering if anyone knew on a 94 where the best place would be to run the line through the firewall. The gauge is going to be in a pod that replaces the dash clock.
