Tubular K member....
Old 07-21-2006, 06:46 PM
TAPOUT
TAPOUT's Avatar
Default RE: Tubular K member....
I put one in because the car was apart, and it was pretty easy. Probably could do it again in 6 hours, start to finish, in my garage. The only problem I ran into was getting the alignment straight enough before taking it to get the alignment done at my friend's shop. I did it all on jackstands, and with the engine supported by a block of wood. I definitely like the extra space in the engine bay more than anything.
TAPOUT is offline
Old 07-22-2006, 02:25 AM
93must
93must's Avatar
The MM for road racing is way stronger than stock and lighter. The stock ones are stamped crap!
93must is offline
Old 07-22-2006, 02:35 AM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
**** coil overs. those things ride like ****.
FiveLiterRiceEater is offline
Old 07-22-2006, 03:35 AM
88stangaruu
88stangaruu's Avatar
I put the PA unit in, took me a weekend, not to bad...your gonna need an engine hoist to hold the engine up while you drop the stock K member...I put it in because im going to be putting a cleveland in by next year and the starter was going to be a bitch to change if it went out. Plus the Hooker headers i have are huge, 2 1/2 primaries. Fitment with a stock K was going to be tight. The PA unit is the other unit most prefer, its lighter than the MM one, about the same in strength. I ordered solid motor mounts and spring perches with it cause im running 4 banger springs. My car handles alot better now ive noticed, not as much chasses flew up front. Wasnt to bad on the install...i got dirty as hell though.
88stangaruu is offline
Old 07-22-2006, 03:22 PM
Twister
Twister's Avatar
ORIGINAL: FiveLiterRiceEater
um, it all depends on the adjustment and the spring rate, coil overs is a far superior design
Twister is offline
Old 07-22-2006, 03:26 PM
92mustangdss331
92mustangdss331's Avatar
i got an aje one they r worth it to me and i dont htink it should take a wk to put in a good wknd should get the job done
92mustangdss331 is offline
Old 07-22-2006, 04:48 PM
w8less
w8less's Avatar
i bought the D&D for the extra weight savings. but i bought the kit when i did it.
w8less is offline
Old 07-22-2006, 05:49 PM
fatmatt88lx
fatmatt88lx's Avatar
definately worth the cost for the weight savings
fatmatt88lx is offline
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
WDScott
08-17-2015 06:38 AM
5.0mustang5speed
10-20-2005 11:44 PM
5.0mustang5speed
09-29-2005 12:31 PM
LMPerformance
01-20-2005 01:42 PM
Quick Reply: Tubular K member....
