gt-40 or gt-40p
gt-40 or gt-40p
I was thinking of getting either GT-40 heads or GT-40p heads. Before you automatically say GT40 are better because GT-40p come off an explorer, do some little research first. If you know what Im talking about, then tell me if you guys think i should go with GT-40 or gt-40p's cause alot of other things need to be changed to use gt-40p (such as headers and sparkplugs for sure. not sure if i could use the valves or valve springs from the gt-40p on my car, or if i could use the same rods or rockers, if you know please tell.) im pretty sure the normal GT40 will bolt up on my 5.0 without changing anything(right?)
So basically do you guys think the little extra punch from the GT40p are worth it? also if my MAC shorty headers would fit on the GT40p(some sites say it can). and if i missed anything else please tell.
RE: gt-40 or gt-40p
Either GT-40's would be nice, i think the P's are a little better though, not by alot though (it could be the other way around...i may be confused.)
I know the BBk long tubes will work on the P's without the sparkplug problems cause the pipes come out from the heads farthur and allow more room for them. Either heads will bolt right onto a stock 5.0 without any change, the stock 5.0 pushrods will work fine also. Good luck...have them ported while they're off, youll thank god you did it.
RE: gt-40 or gt-40p
Actually the P's are better as far as more HP goes?
Do a search for this there has been at least 5 posts on this in the last month including one where I took pictures of ther clearence issues with the P heads.
RE: gt-40 or gt-40p
I think the 95 to 97 Explorer's are GT 40 and the 97 1/2 to 2001 are GT-40P but i dont know i ther its a gain of HP because there are Caston Iron ..
In my case some person is saleing me a hole 2000 Explorer engine for $500 it comes from the oil pan to the GT 40 intake should i buy it?
RE: gt-40 or gt-40p
RE: gt-40 or gt-40p
you're confused on your GT-40 heads........
GT-40 .... little better than stock
GT-40P ..... little better than the GT-40
GT-40X ...... $1000 aluminum, much better than stock
GT-40Y ....... same as X just not as good
GT-40Z ....... aluminum race head
go with the P's to save money, but you might have header
fitment issues with the spark plugs.
RE: gt-40 or gt-40p
you can just expect idle headaches
ORIGINAL: 95STANG_GT
why geting the ECU from the Explorer i just buy a 90 stang GT ECU because my buddy told me that my car u can't put a cam on the SN95 because of the computer ...
