aluminum 1.6 roller rockers...
RE: aluminum 1.6 roller rockers...
I think the stock are 1.5's, 1.6 rollers will give you at least a 25 to 35hp gain but you need to change your pushrod a to .100 long over stock. It is well worth it. Also have you sub frame connectors put in as soon as possible, you would not be leave the stiffness it adds to a convt.
ORIGINAL: Crump_4
I went to roller 1.7 and am happy, also I didn't use longer pushrods, the bolted on with a little shim adjusting. Going from 1.6 to 1.7 will give you about .030 more lift and longer durration. I wouldn't wasted the money on 1.6
Well, I ported my heads at the same time, so I am not really sure of the gains on the rockers alone. I don't feel like I wasted my money on them. I would buy them again(the 1.7 is an upgrade)
The rockers I got were comp cams energizers and they were direct bolt ons. I had to shim only because I decked my heads, but I know other people who had to shim. I guess I also know people who had to get longer pushrods also, but if you go with the comp cam one, you should be alright.
ORIGINAL: jlabster
ok, 1.7's are fine but what size cam and how much clearance did you have. I have been messing around a little with it myself and found at high rpm's I may bend a valve.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
wishinsky
09-21-2015 09:48 AM
