next step in engine mod
RE: next step in engine mod
what certain tool is that? ive always just used an impact and had no problems.
Pinion depth is easy to figure out first you look at your pinion gear it will have a no. on it like 2 or -2 you get the point. Take the bearing off of original pinion gear and use the shim as a base line. If factory gears have no number or a zero then add or take away the number on the new gear TADA you know what shim you need for the new one.
Old gear number -1
New gear number +2
measure orig pinion shim .035" thick (example only) Pinion depth would be .034" variance is -.001
shim needed for new gear .036 Math is easy!
Old gear number -1
New gear number +2
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
waid302
09-14-2015 11:19 AM
Calizic
08-28-2015 01:46 PM
inyadreems
08-21-2015 09:10 AM
