HELP!!!!! went to the dyno!!!
Old 07-22-2006, 08:52 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: HELP!!!!! went to the dyno!!!
i run a breather on each valve cover, pcv system and its plenty of crank case ventalation for a sc motor
luckythirteen13 is offline
Old 07-22-2006, 08:56 PM
r.barn
I dont think the Track Heat intake is equipped for EGR.
He probably had to block off some of the EGR stuff.
ORIGINAL: Jasperstang308
the pcv is brand new. but i called the engine builder a little bit ago and he said he had to block off something when he put my trickflow track heat intake on and thats what he said i needed to buy one of those k&n breathers for the valve cover. do u know what he might have blocked off?
r.barn is offline
Old 07-22-2006, 08:58 PM
HACKGT350
HACKGT350's Avatar
my car is mostly stock and i run a k&n breather. could be why my car never gets over 175* with a 180* thermastat that and the active hood scoop
HACKGT350 is offline
Old 07-22-2006, 08:59 PM
Stiffclutch
I must be way off but i thought that Blowby was a sign of bad rings causing combustion pressure down in the crank case which caused the oil to shoot out like you are saying? am i wrong in thinking this?
Stiffclutch is offline
Old 07-22-2006, 09:02 PM
lookinforastang
I ♥ Acer
blow by is too much pressure in the crankcase
pcv is clogged
pressure cant go out
it will find a way (ie. the dipstick)
lookinforastang is offline
Old 07-22-2006, 10:01 PM
92hatchLX
Don't mess with it your self, make the guy that built your motor **** with it, it's not your problem, it's his.
92hatchLX is offline
Old 07-23-2006, 03:26 PM
Erik90LX5.0
There is a screen between the pcv and and the baffle at the bottom of the lower intake plenum.I cleaned mine out when installing my trickflow .What I assume he blocked off was the galley plug at the rear of upper rail of the block .Trcik flow recommended it because they stated that you might suck oil thru the intake .Blow by is caused by one of two things a bad pcv system or bad ring sealing.Being a 347 stroker some of the kits run the oil ring thru the pin area hence causing a possible bad seal .Tkae back to the engine builder he is ultimatley responsible for this isssue. hope that helps[&:]
Erik90LX5.0 is offline
Galactic
Mustangs For Sale
04-29-2019 02:56 PM
articman
06-21-2018 11:45 PM
heslekrants
09-23-2015 04:02 PM
The01Cav
North East
09-05-2015 03:39 PM
The01Cav
Maryland Regional Chapter
08-31-2015 04:12 PM
Quick Reply: HELP!!!!! went to the dyno!!!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
