IDELS GREAT BUT DRIVE LIKE CRAP!!
I have a turbo 302 run 8 psi that has 42lbs injectors, upper and lower intake and 76mm MAF, 255 fuel pump ,70mm thottle body. It idles great but as soon as i start to drive it sputters and want to die! It also has white smoke coming from it. It run good when i take the turbo off but like crap when it on.
Fuel problem?????? I have been work on this problem for to many days now and NEED HELD!!!!!!!!!!!!!!!!!!!!!!!!!
RE: IDELS GREAT BUT DRIVE LIKE CRAP!!
If the head gasket is bad blown it will run like crap because the cylinders that have the leak now have very low compression. Do not drive on it you will destroy your motor that way. Do you know how to do a compression test.
i to agree with the head gaskets or a cracked block. when you are under pressure from the turbo it expands the damage and allows more coolant to enter the cylinders. pull the radiatior cap off and let the engine idle for a while, let us know if there are any bubbles showing up in the radiator.
i bet your close to 380 horse at the wheels, that little guy stould scoot!
