REAREND NOISE...NEED HELP
My 91 fox is making a howling sound coming from the rear of my car the noise only goes on when I get on the gas has anyone had or heard this type sound? My friend that I bought the car from put 3:73's in it but said the backlash was close to perfect....rearend? bearings? gears? need your help
RE: REAREND NOISE...NEED HELP
It could be the gears, but if it all the sudden started making a howling noise, I suspect the axle bearings. How many miles are on the car and have they ever been changed? I don't recommend it , but when I was dianosing noises in a 71 Cutlass I used to own with a 4.11, I just put it up on very solid jack stands and had a friend run it until I could determine the noise location. If the rearend has never had a fresh set of axle bearings, I would just replace and see it solves the problem. Sooner or later you'll have to replace them anyway.
PB
PB
