5 Lug rear disk brakes
i'm putting an 8.8 disk brake rear in my 87 coupe from a lincoln. i have the stock gt brake master cylinder in my car now for front disks and rear drums, question. will i need to upgrade the M/C for the rear disk brakes??
RE: 5 Lug rear disk brakes
You can actually keep the booster, you just turn the master screw in the center I think 1/2 turn outwards and you should be alright.
Different story if you're getting PBR front calipers tho.
get the lincoln front calipers also they are 73 mm and get an svo master cylinder and fab up ur brake lines to adapt the threads then u will have svo spec braking!
Galactic
04-29-2019 02:56 PM
musnicki
09-23-2015 07:11 AM
