Electrical help needed ASAP
#21
RE: Electrical help needed ASAP
ORIGINAL: 5.0 MPG
follow that wire! It should go directly to the starter switch. make sure. it should be a red and light blue wire.
make sure that larger spliced wire isnt connecting to any other device.
#23
ORIGINAL: 5.0 MPG
you followed that wire back inside the compartment to the ignition switch under the steering column?
#27
ORIGINAL: 5.0 MPG
can you take a picture of the solenoid?
#28
I gues the best thing you can due is just run a high powered switch into your cabin and skip the solenoid... That would be the best, but unsafest way if you never find the fix. I just got done reposting about my starter solenoid, just blew an hour ago, and realized that it must be a bad ground. I myself also got a cheap one from autozone, hopefully I will get to the end of this myself.
Anyhow, I would check your grounds, perhaps even replace that wire to the ignition switch.
#30
ORIGINAL: gr84u
