Afr 165's or 6psi s/c?
RE: Afr 165's or 6psi s/c?
another good reason to go with the heads over the charger for now is you dont need premium fuel for the head swap, your gunna save .30 a gallon easy. it may not seem like much but its almost $5 a fill you will save and still have the same power. i would go with #24 injectors if you do the head swap and larger #30 if you do the supercharger.
i would personally so with an intake first because if you put heads on with a stock intake you wont get the full benefit of the heads. i would start there then the heads then maybe a s/c with a good tune
Soldier GT
08-12-2015 03:46 PM
