How do you get the F*****G lock actuator out???
RE: How do you get the F*****G lock actuator out???
i wouldnt drill it out all you have to do is remove the rods and slip the actuator out of its holding brackets. you could even use the old bracket with a new actuator. thats up to you if you want to re rivet and all that mess...
[IMG]local://upfiles/4191/9CEB3DABBA3F4341B5A7CA49601B0F61.jpg[/IMG]
the rivot is on the side on the door that would be facing the rear of the car when the door is shut... the rivot is a special ford rivot, its oversized and looks like a big washer, you HAVE to drill that out to remove a frozen actuator, because the new actuator has set screws/pins in it for the new links and its impossible to set those with the actuator in the door. Then go to a ford parts store and get a new rivot for a few bucks, the kit i had came with a bunch of different links be sure to replace with the same link and put the actuator in the proper posistion so that when u lock it locks and unlock it unlocks.
I believe the holding bracket is facing up so you cant push down on it... i think, not positive.
Drexl sounds like someone forced the door lock and that bent the link, 5.0 resto has a kit for forty bucks and the rivot is $2.
ORIGINAL: 7upedition
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
