How do you get the F*****G lock actuator out???
I can get the rod from the actuator to the door lock out of the hole. Is there a washer or bolt or something on the back of the lock where the rod goes in? And how do you get the whole actuator off the door? I cant find a bolt or anything but its stuck on there somehow...how do you get this damn thing off???
RE: How do you get the F*****G lock actuator out???
drill otu the rivet that will let the actuator loose from the door. =with the dor panel removed unplug the act. and turn it sideways the end on it is not straight u have jiggle it and it will fall out like this shape
yeah i had to basically pull every last rod out just to get the actuator out because with the rods connected to it didnt allow me enough slack to just unhook the actuator.
