anyone have pics of installed sub frame connectors?
i have weld-in subframe connectors and dont know where exactly to mount them bc i lost the instructions. Can i see pics of your mounted subframe connectors anyone???
RE: anyone have pics of installed sub frame connectors?
These are from a 1989 Gt Vert I used to have. The sub-frame connectors are Kenny Brown. Work done at Springfield Motorsports in Springfield Va.
Grind down the metal to get a clean surface to weld to...
Cross braces bolted, ready to weld...
Welding done, after this he sprayed some paint on the clean metal to keep the rust down to a minimum...
ORIGINAL: I3atR!ce
make sure when you do it you have the car on its suspension. if your going to use a lift, find one what is drive on (not a body lift.)
because when you weld them on, you want the body sitting exactly how its going to sit when its on the ground. the car will flex a little when you set it down, especially a 'vert.
