alternator heating up w/ign. off
Old 07-25-2006, 04:55 PM
greenstreak9205
greenstreak9205's Avatar
Default alternator heating up w/ign. off
so im pretty clueless on this. i just rebuilt the motor got about everythin ready to b on the street except for breakin in the cam. everythin was working just fine before i took it apart, but now i noticed that when i hooked up the battery that the alternator heats up. what could possibly cause this? this happens when i hook up the battery w/out even running anything
greenstreak9205 is offline
Old 07-25-2006, 06:28 PM
samseed101
samseed101's Avatar
Default RE: alternator heating up w/ign. off
I can only think of two things. There could be a problem with the wiring (ground or perhaps even crossed wires.) It could also be a failing diode.
Those are the only things I can think of off the top of my head.
samseed101 is offline
Old 07-25-2006, 06:32 PM
gr84u
gr84u's Avatar
I was gonna go with failing diode as well, perhaps try taking your alternator off to get it tested. Is it stock? An aftermarket, perhaps a one wire? See if there is also a draw in your car, take off the negative off battery and put a vm between the negative connector and the battery - post.
gr84u is offline
4cylinderplus2
10-09-2020 07:45 PM
PaulH2
20
01-31-2016 09:48 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: alternator heating up w/ign. off
