Where does this hose go?
Hi, im putting my manifold back together after changing the injector o rings and I have run into a little problem. I can't figure out where this hose goes... I remeber all of the other ones but I don't even remeber taking this one off... It looks like it sits right at the end of the ports.... but there is no fitting back there.
the hose is marked in red
thanks a lot for the help.
RE: Where does this hose go?
thanks for the quick reply, there is a hole where the hose looks like it goes, but i stuck my finger in it and it dosn't go anywhere. Is that it? also i would go around the hose, not inside the hose.
Well if the empty hole is in the back of the lower intake manifold, it needs to have a rubber grommet, a PCV screen and a PCV valve in it, don't just stick the hose in their. Did the hole have anything in it when you took it apart???
ORIGINAL: 92hatchLX
Thank you, that diagram helped a lot, it must have fell out when i took the plenum off. the Pcv valve was laying on the back of the engine, thanks again
