Whats the best MAF / TB combo?
Silly question, I know. But I see people on hear with 90mm MAF and 70mm TB's (Blacksnake) I was thinking of going with a 73mm MAF and 75mm TB. I am going to be reconditioning the block this winter as well as bore and install a 331 stroker kit. I plan on a KB 2v or 3v...I want that available 18 psi of boost!!!
Will the 73 MAF and 75 TB suffice with the addition of a h/c/i and blower later??
Probably not a big deal...if worse comes to worse I can bore the TB and MAF as well, right?
RE: Whats the best MAF / TB combo?
you'll need to go with a larger combo than that for a s/c and stroker kit... 90mm MAF and 75mm TB, the TB should be the same size as the port on your intake so that you dont loose air velocity, if you go larger your creating interference from the lip created, people blend them together, but i'd just get the same size for max airflow. And the MAF can be as big as you want but always should be larger than the TB or it becomes a bottleneck, just get it cal'd to the injectors your going to run
ORIGINAL: 7upedition
You CANNOT bore out the MAF or the TB. Well, I guess physically one could, but it would not be a good idea.
The airflow calculations in the computer will be challenged with all the other mods. You won't want to mess with changing the diameter of the MAF.
jason
jason
i was talking about the intake being bored out and after all those mods wouldnt he get it dyno tuned and have them burn a chip for his setup?
I never assume that a custom tune will be done, onless stated otherwise.
Some folks have done very well with out custom tunes.
Even if a custom tune is done, I still don't think boring the TB and MAF is a good idea. In the old days they did this quit often, but that was only because there were no other alternatives on the market.
jason
jwog666
12-27-2021 08:09 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
