Fuel Injectors: Matched? Blueprinted?
I need to upgrade my injectors. I need some 42's.
My selection up here in Canada is limited. I'm looking at some non-match FMS 42#/hr injectors.
Are matched/blueprinted injectors worth the extra cost? How much deviation is there on these? Does Ford match injectors at the factory?
Any input would be great.
RE: Fuel Injectors: Matched? Blueprinted?
in order for them too flow exactly the seem they need to be sent off to be flow'd match......unless you have a high $$$$ engine do you need this as all 42's flow within a few % of each other..looking at your mods 42's would be too big and a tweecer or pms or a chip would be needed as the 42's will be out of the stock calibration limits...most noticable in starting the car as you'll have to floor it to start
It's got a chip. I'm running 30's but they are old and must be plugging. I've also got a lightning maf and it sounds like they are a better match for it.
I'll just go with a regular set.
Thanks for the replies.
Well the tuner and I have come to the conclusion that the injectors are plugged. He can't tune out a lean that happens aroung 4300rpm. We boosted the pressure and it richened up but only leaned out a little bit higher. The pressure was steady the whole run. Maf was not pegged, it read 3.7 at 5000rpm.
Heads and cam won't be for a couple of years. Would my mpg go down with 42 as opposed to 30? Not that I'm getting good mileage now.
mrappe
09-26-2015 10:16 AM
46, 50, blueprinted, boostmaster, craigslist, flow, fuel, injector, injectors, match, matched, matching, mpg, mustang, upr
