4.10s this week!!!!
RE: 4.10s this week!!!!
Good point...........hell I need to get a new radiator now for sure........
How about that 107.00 fan from Jegs has anyone used it yet? I think I am going to aluminum on the radiator...........
jjegs has a good kit that has everything for like 650: aluminum rad, hi po water pumo, hoses, electric fan, thermostat, and a few other things..... thats what im gettin when i take my loan out
ORIGINAL: 95hooptey
If i were you i would do what i did with my ignition kit. I looked at jegs 5.0 ignition kit and then called summit and they threw it together for like 75 bucks cheaper!!! i dont know if the cooling kit is cheaper through summit, but it is worth a try, i am going to do that when i get some more money[&:] lol
ORIGINAL: 91lxstang
ORIGINAL: 95hooptey
if u have an AOD the best setup u can get for the street is
4.10
shift kit
trans cooler (2 is even ideal for cars that will see abuse)
higher stall
aluminum driveshaft
gears should be chosen based on ur cars use if its a track car go all out if its a DD 3.55-3.90 is ok but many ppl have 4.10's with their DD's
all depends how ur cars used
4.10
shift kit
higher stall
aluminum driveshaft
