Transmission not going into gear...
RE: Transmission not going into gear...
ORIGINAL: Black Snake
No one else?
Another question. Is it suppose to go into gear when the car is off and the clutch not pressed in?
No one else?
Might be your throw out bearing, clutch was improperly installed, tranny... just guesses.
If the tranny goes into gear when the car is off, it's your clutch/cable/quadrant....probably can't handle the spec setup. I went w/ the steeda setup. It's a PITA to install, but works like a champ. I put a walkthrough for the install in the tech stickies.
OK I just Ordered a BBK clutch Quatrient and cable.
Are those preety good?
I torqued the clutch at 30 ft/lbs.
Ok I ordered the BBK 1505 clutch cable and Quadrent, without the firwall adjuster.
My next question is, Do I need that Firewall adjuster? Is it nesessary to have it?
i had the same problem today actually... came to a stop light, put my car in neutral, let out the clutch, and when i went to put it back into first it didnt wanna go, but i went from 2nd to 1st a couple of times and it finally went all the way into first.... kinda weird
