haha if i knew the times i could run it would be easier. i got a nitrous kit commin so i think im still gunna do the fuel pump, sould i do 24lb injectors??? or 30lb with the trick flow if i still get it
wont my car run ****ty if i put 24lbers i nthere and isnt a a 225 lb hr pump overkill?? if i can run em without HURTING preformance ill do it
if you use a calibrated mass air meter it will run ok, and our cars use a return-style fuel system, so it only uses how much it needs. the 255lph pump can flow that much if needed, not all the time.
