Cam and head questions...
RE: Cam and head questions...
AFR's [:@]. Why does everyone pimp their heads??? Theyre good and all but TFS are better IMO, for 2 reasons. 1- the valves are slighty askewed, which helps give it a straigter shot to the cylinder, and 2- you can run up to a .550 lift cam with out flycutting. As for a cam, screw the letter cams, theyre good "generic" cams, but getting a custom grind thats specifically designed for your motor will be MUCH better. Itll be a little bit more expensive, but well worth it. Just my .02
-P.
-P.
Is it a street car or mostly strip?
If its street your going to want low/mid power...so i would suggest AFR 165's and a TFS R Intake and TFS Stage 1 Cam
If your looking for more strip time, i would suggest TFS TW 185's TFS Stage 1 cam and TFS R intake.
ORIGINAL: P Zero
-P.
-P.
Custom cams are bad *** but he's going to be running the 302. I think it will be wasting his money unless he was to do a 306,331, or a 347 then I would recommend he would get a custom cam. As far as AFR heads go's every one pimps there heads cause I there good quality heads. Not saying the others aren't just AFR has a great reputation not just for 5.0 but for the LS1's as well. Just my opinion.
Thanks for the suggestions guys but this isnt a 'what will get me into the 12s' thread...just want some advice as to what heads, cam, and headers to run.
My car is a dd so its street mostly.
So if anyone cam suggest good heads, lumpy idle cam and headers for a high 12 car itd be appreciated.
ORIGINAL: VigCS
As far as headers go BBK ceramic coated long tubes or BBK equal length headers are my favorite. I like Bassani too but are kinda expensive. I personally don't like Mac. Good luck on your car.
ORIGINAL: VigCS
Will long tube headers require me to change my exhausr at all? h pipe with high flow cats and super 40 mufflers?
Exhaust no as far the H pipe or X pipe yes. You gonna have to he a short H or X pipe.
ORIGINAL: P Zero
-P.
-P.
okay...so what cam would you all suggest? keep in mind i would like a lumpy idle...i love that.
seems pretty obvious the AFRs are the suggested heads =)
okay so I have decided that AFR 165s are out of the question (too damned expensive) unless I can get a used set. What is a cheaper, possibly sub- $1,000, good alternative?
Also, any suggestions on a good low-mid power cam with a lumpy idle?
