Constant Control Relay Module
Old 07-28-2006, 09:46 PM
Dizzydean
Dizzydean's Avatar
Default Constant Control Relay Module
What role does the CCRM have during the starting process??
I have an ongoing starting problem and the Ignition module has been replaced to no avail. I had a Ford parts guy tell me that it could be the CCRM? After reviewing the Chilton's manual schematics the best I can tell is that the CCRM provides power to the Powertrain Control Module (PCM) and powers the fuel injectors. The Spark OUT (SPOUT) signal to the ignition module comes from the PCM as well.
I am so frustrated as to this on again off again starting problem
Dizzydean is offline
Old 07-28-2006, 10:06 PM
Joel5.0
Joel5.0's Avatar
Default RE: Constant Control Relay Module
Check https://mustangforums.com/m_1718648/...tm.htm#1723564 the CCRM has all the power relays for the EEC, Fuel Pump, Rad Cooling fan (both speeds), and the AC compressor.....
Joel5.0 is offline
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
10-06-2015 08:45 AM
UrS4
10-03-2015 06:23 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Constant Control Relay Module
