gauges(a/f)
#21
RE: gauges(a/f)
the problem with n2o is that you dont always use it. you can go wot without using the n2o so for max performance it would be nice to have a tune for when not on n2o and a nitrous tune. i think what your coworker may have been trying to say is that if you get a custom chip for the n2o, your always running a n2o tune even if you dont spray. thats the beauty of a flip chip or running an EMS that holds more then one tune.
#23
RE: gauges(a/f)
If you are going to spray, you first need to have a way to adjust timing. Timing retard is more important to prevent "KNOCK/PING" whatever you call it then AFR. Spend money and get LM-1 so that you can log.... Who has time to drive WOT and look at the gauages.... 2nd is the AFR, you need to reduce the injetor cycle but not necessarily immediately.... Well, that is at least what I used to do in IMPORTS tuning (RICER you may call it)... If money is a concern for now, I would get the EGT gauage first... It is cheaper than LM-1 and will serve purpose of monitoring if AFR is lean....
#25
RE: gauges(a/f)
ORIGINAL: Goosepoop302
well to retard the timing isnt really na issue all i have to do is rotate the cap to retard the base timing i thoiught
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
