Timing Advice
Old 07-29-2006, 11:30 PM
gt884me
gt884me's Avatar
Default Timing Advice
all right went out to set my timing, hooked up my light and it read 21*, shut off car unplugged spout, started car and set timing to 12*, put spout connector back in and boom jumps right back up to 21*......WTF!!!!!.....how can this happen? And what can I do to fix it? I know you guys know please help me!!
gt884me is offline
Old 07-29-2006, 11:32 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Timing Advice
Because that's what it's supposed to do.
PRO50SC is offline
Old 07-29-2006, 11:33 PM
Twister
Twister's Avatar
+1
Twister is offline
gt884me
gt884me's Avatar
Its supposed to jump? Well if my base is set right guess its ok
gt884me is offline
Old 07-29-2006, 11:34 PM
silver91gt
silver91gt's Avatar
the spout connector allows the computer to adjust the timing.
you dont need to shut it off to remove/replace the spout.
spelling error
silver91gt is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Yes, the timing is controled by the ecm, the "base" timing is it's set point. Then it takes over from there.
PRO50SC is offline
Old 07-29-2006, 11:36 PM
gt884me
gt884me's Avatar
Allright thanks for the help I'm heading back out!!
gt884me is offline
Old 07-29-2006, 11:58 PM
luckythirteen13
luckythirteen13's Avatar
thats normal. in drive with my foot on the brake i run 23* total timing at idle <--i know this because my PMS says so
luckythirteen13 is offline
Old 07-30-2006, 12:05 AM
95hooptey
95hooptey's Avatar
Yea, It freaked me out the first time..........mine showed 30*.....................and then I took off the spout and it showed 18-19......Holy shizz!! Thats why the damm things been pinging like a chevette on bad gas!!
The donkey who owned this car before me decided he was going to get as much HP out of it without spending any $$$......You should see what I had to fix!!
95hooptey is offline
Old 07-30-2006, 12:59 AM
danfrompa
danfrompa's Avatar
I am new to 5.0 Mustang.
Is the timing controlled by the ECU in fox body mustang? Is it mechanical? If it is driven by the ECU, Does the timing vary based on TPS, RPM, & MAP or MAF electronically?
I am in the market for the FOX BODY mustang. What year came with ECU controlled timing? Most likely I will be picking up the car with MSD ignition with lower/upper header, heads, cam, injector, & fuel pump.....
Thanks in advance,
Dan from PA.
danfrompa is offline
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Timing Advice
