Its looks like a big can on the pass side firewall, with the pressure switch on top. You want to replace that cause that is what catches all the garbage in the system. Get the drier with the hoes already with it and replace the lowside line and also on the foxes, buy the hose with the fingerscreen in it. I bought the fingerscreen and found out you have to cut the old one out and buy a kit to replace it. It was cheeper to buy the hose with the finger screen in it.
Also, the orings will be in the connector ends, like on fuel line connector!! You have to get the springlock tool unless you have it already, Its not to hard to do. Just take you time. Make sure you get refrigerent oil also. To lube the orings and put oil in the system.
