Pistons backwards!!!!
Old 07-30-2006, 07:25 PM
  #21
Twister
Twister's Avatar
Default RE: Pistons backwards!!!!
ORIGINAL: randy78045
Alright, im an idiot... i read this entire thread an still dont know what the hell ya alls talkin aboot... [&:] How in the hell do you install a piston backwards???? Me thinks youd need an overhead cam for that...
here is a picture of a stock 86 piston, see the dot, that points to the front. Putting pistons in backwards would put a valve relief on the opposite side and risk bending a valve in the real world. Now a race shop that has a bunch of tools and a machine shop can modify the pistons, but if it was my car, I would not risk bending my valves
[IMG]local://upfiles/28634/364D0EDD4A49401F8A490A41FE90609C.jpg[/IMG]
Twister is offline
Old 07-30-2006, 07:30 PM
  #22
randy78045
randy78045's Avatar
Thanks...
randy78045 is offline
Old 07-30-2006, 07:53 PM
  #23
ckyguy68
ckyguy68's Avatar
yes, a backwards piston is the mistake of an idiot building an engine. backwards piston=bent valve... engine failure... etc.
ORIGINAL: Twister
ckyguy68 is offline
Old 07-30-2006, 07:58 PM
  #24
88stangaruu
88stangaruu's Avatar
You have to cut valve reliefs on the other side, and on some pistons they have double valve reliefs. In an all out racing engine its worth it, for the street....dont waste your time.
Below is a link, in that buildup, he installs the pistons backwards to increase piston dwell time at TDC/BDC and as Tinman said, to get a better rod angle.
http://www.jason.fletcher.net/tech/sherman/sherman.htm
88stangaruu is offline
Old 07-30-2006, 08:58 PM
  #25
89gtsleeper
89gtsleeper's Avatar
Yes this is a real trick, and could only be done with slight modification to the piston and a few other things... and yes it is only a ew hp difference, but in a stock class, every hp is an advantage over the next guy!!!
89gtsleeper is offline
Old 07-30-2006, 09:51 PM
  #26
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: Twister
I must be blind because I do not see a valve relief in that piston[&:]
JD1969 is offline
Old 07-30-2006, 10:07 PM
  #27
Twister
Twister's Avatar
ORIGINAL: JD1969
ORIGINAL: Twister
it is an 86 piston, the one year of the H.O. that was a flat top piston, and why you have to either notch or swap out 86 pistons for a big cam or aftermarket heads
Twister is offline
Old 07-30-2006, 10:56 PM
  #28
5speed GT
5speed GT's Avatar
well I can say 100% putting the pistons in backward does nothing. Let me start by saying I am a Mercury Outboard Motor mechanic... and I have put together hundreds of outboard engines(v-6 mostly)anyway, Mercury has a different numbering system for the cylinders. So when I pulled my 5.0L apart... I numbered them as ford numbers them, so 2 months later, durring re-assymbly, without paying attention I put the pistons in as Mercury numbers them. I didnt realize it unil it hit me when I was putting it back in the car. I made a few calls and was told it wouldnt hurt anything. and I can say, with 4 of them in backward(on the wrong bank) there has been no difference at all
5speed GT is offline
Old 07-31-2006, 12:52 AM
  #29
hayden
hayden's Avatar
well im not sayin its true by any means anyways.... thats just what "he" said
hayden is offline
Old 07-31-2006, 11:52 PM
  #30
tinman
tinman's Avatar
Hey Guy's; remember that I was doing this in about 1979.....
I'd sure like to know what 'tricks' are being used nowadays for stocker to get 'just a little' more........
I've got some ideas/thoughts that I won't post about but it all comes down to real chicken sh-t machine work/balancing....
Remember, it's a good idea to know how to make a 'stocker' work before throwing down $$$$$ ONSTROKER KITS, HEADS, CAMS, and stuff...........
tinman is offline
Quick Reply: Pistons backwards!!!!
