Pistons backwards!!!!
#31
RE: Pistons backwards!!!!
well ive never heard this, atleast of people doing it on purpose. but i know if you put hem in backwards, your gonna beat the hell out of the bocl at the bottom of the cylinder walls. plus i dont se how you could gain power from it, would you loose it considering youd be running a smaller compresion ration? some one please correct me if im wrong, i just dont see how you could gain power from this.
#32
ORIGINAL: fordboyyfm
#33
because technically the piston wouldnt be coming up as far. the piston pin os off centered, if there on the right way the rod and pi are closer to the inside of the block, you flip it around it will be on the outside, there for the piston would be a bit lower at tdc, so less compression, not much but it would be less.
#34
so basically by installing a piston backwards and having to cut reliefs into a piston crown, you're turning a non-interference motor into an interference motor... what a waste of time and energy.
#35
ACTUALLY the best thing to do is put the whole piston and rod assembly in upside down. take some jb weld and jb weld the top of the pison to the crank, then duct tape the rod to the piston so it stays still and doesnt slap around. now, drain the oil out, and fill the oil pan back up with peanut butter and jelly. and now your ready... fire that bad boy up!!!!
#37
And on stock 5.0 pistons, its double valve reliefed. So...there goes that, and anyways, most engines that use bigger cams your going to have to cut the existing valve reliefs even deeper, so nothing changes there either.
Hey Guy's; remember that I was doing this in about 1979.....
I'd sure like to know what 'tricks' are being used nowadays for stocker to get 'just a little' more........
I've got some ideas/thoughts that I won't post about but it all comes down to real chicken sh-t machine work/balancing....
Remember, it's a good idea to know how to make a 'stocker' work before throwing down $$$$$ ONSTROKER KITS, HEADS, CAMS, and stuff...........
I saw on another forum where some guys were in a competition to see who could go the fastest with a 306 and some E7's. I was reading (and these guys are serious racers, old time hot rodders) and they were talking about how they were getting into the mid-10's and low 11's on just garage ported E7's and making a tad bit over 400hp on them totally N/A. Now if that isnt just sheer talant and innovation id love to see it.
uberstang1
09-20-2015 06:42 PM
