on the passenger side of the car there are 2 plugs that a 3/8 ratchet will fit into. The top one is the fill, the bottom is the drain. leave the bottom in, take out the top one and add fluid until it starts comming out of the top hole(where you are filling it)
you can also add in the top of the trans if the shifter is out , but either have to remove the top plug , or if you've drained it completely, pour 2 3/4 qts
lol just get a short shifter (great time to get it!!!!), and pour it through the top of the shifter hole. that's the easiest way, cuz the other way involves thin hoses and gravity feeding it into the check hole in the passanger sided of your trans.
