something broke off in ignition..
my car is currently sitting in a parking lot and i need to move it.
problem is the key won't go into the ignition so i can't turn it over or even move the shifter out of park.
The steering wheel is not locked.
is there some kind of quick fix??
help quick please!
help quick please!
RE: something broke off in ignition..
i don't know. i can kind of force it in but it will sit crooked.
it looks like there is a smooth pin at the center of the lock. is that supposed to be there?
thanks for the reply
Not sure, does the outer housing of the key switch move at all. The Taurus's had a problem with that. You had to turn the outer part to line up the key part so it would go in.
ORIGINAL: fordguy17
yeah, i can wiggle it back and forth.
not sure what you mean about the lining up part.
i though the whole assembly turned as one?
ORIGINAL: fordguy17
oh...
no i didn't check that, but i will.
any other ideas before i ride out there again?
thanks pro!!
oh...
thanks pro!!
Primetime, the problem though is the key has to be in the run position in order to push the release pin in to get the cylinder out. Otherwise, it's a painstaking operation.
well theres a thing where the ignitino goes into the bellhousing its like an ignitinon gear, mines stripped out in the bellhousing which with my key in the ignition it turns too freely n it wont turn over because the things stripped. i dont know what its called so im screwed. i just need a whole steering wheel column so i can part it.
