High temprature problems
RE: High temprature problems
What CFM is your fan rated for, it may be enough to cool the motor at high RPM's, have you checked concentration on the rad. fluid, as far as lean goes, have you pulled the plugs and looked at those? try to get a wideband air/fuel ratio monitor and you'll know for sure if your running lean. Good Luck
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
