t5 install help
t5 install help
well i got my tranny rebuilt, and took the night ti in stall my new clutch and put the bell houseing back on but when i got ready to put the tranny back in it would not go , i took my lineup shaft to check it and ever thing was right. and ideas or tips???
RE: t5 install help
you just got to have two people, one holding it up in the front and you get behind it and hang on to the tailshaft and sorta 'drive it'. Just make sure you dont mess the TB up when your moving it around in there. If you have to, turn the input shaft some to see if you can get the splines to mate up.
RE: t5 install help
i did my clutch a few weeks ago took two people and we had to turn input shaft a lil to get it to go but once we got it started it went on in so far no complaints i went back a few days later with the torque wrench to double check bellhousing and tranny bolts as well as driveshaft nothing had backed off
RE: t5 install help
I think when we put ours in we had to push the clutch pedal. I think that we put the tranny in as far as we could and then I pushed the pedal and it went completely in. You'll need a 3rd person.
