Clunking in driveline?
If your rearend is going out, will it usually make a clunking noise, or a whining noise? What would give a clunking noise when you get on the gas, but only do it some of the time? Any ideas.
RE: Clunking in driveline?
ORIGINAL: P Zero
U-joints can make a clunking noise. Get the heavy duty GREASEABLE spicer U-joints.
-P.
-P.
I plan on pulling my driveshaft out this weekend, but I honestly don't know what to look for in terms of a bad u joint. If I pull the driveshaft out is there something I should look for that would let me know the u joint is bad?/the cause of my clunking noise?
replace your quad shocks the ones that go horizontal. mine made the same clunking when i accelerated and when i breaked hard the axel was moving too much cause the shocks were trashed. replaced and havent had a problem since.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
91StangOwner
08-20-2015 11:34 PM
