91 mustang lx
RE: 91 mustang lx
When this happens, with the key in the on position, do you hear the fuel pump whine?
If you turn the key off and turn it back on does it then start right up or do you have to do something to get it to start ie: take battery cable off, pull or reset a fuse, turn the steering wheel, slap your girlfriend ect.
RE: 91 mustang lx
check for power and ground at fuel pump when this happens (with a old headlamp not a little test light) if you have both then your fuel pump is bad
sometimes you can also tap on the tank with a hammer then try to start if it starts then you need a fuel pump
hope this helps
hope this helps
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
'stangdude
08-12-2015 01:27 PM
