throttle body help - MustangForums.com
throttle body help
Old 08-05-2006, 02:02 AM
Rey5.0
Default throttle body help
does a 70mm throttle body and spacer fit on a stock 87-93 5.0 intake manifold?
Rey5.0 is offline
Old 08-05-2006, 02:52 AM
ooticamitica
Default RE: throttle body help
yup so buy it :-D
ooticamitica is offline
Old 08-05-2006, 03:25 AM
92hatchLX
It will fit with a little bit of massaging on your intake manifold, just get a dremel and a burr and smooth out the lip of the hole that your egr spacer bolts on to (on the upper manifold).
92hatchLX is offline
Old 08-05-2006, 03:33 AM
bossco302
I ♥ Acer
ORIGINAL: 92hatchLX
uuuh you might also want to suggest that he does this burr and smoothing with the whole upper intake off the car so he can clean all the shavings off that way it dosent end up inside the motor.
bossco302 is offline
Old 08-05-2006, 03:48 AM
89GTRed
i didnt need any "massaging" to get mine on. the bbk 70 mm tb and spacer BOTH went on no problem just popped my old ones off and slapped new ones on. easy to do just take your time and watch where everything goes. should be pretty self explanitory though. good luck.
89GTRed is offline
Old 08-05-2006, 04:44 AM
FullAuto
ORIGINAL: 89GTRed
It will physically bolt right on, but now you have a lip inside.
FullAuto is offline
UrS4
10-03-2015 07:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 11:29 AM
guitarman376
09-30-2015 06:54 PM
GLOCKer
09-28-2015 08:36 AM
2poor4u2
09-26-2015 12:08 PM
Quick Reply: throttle body help
Featured Sponsors
