My car going to sh*t???
K, I don't know exactly what's going on with my car, but I'm burning oil...my exhaust is smelling extremely rich, and my gas mileage is HORRIBLE!!!!!!! This has happened since installing the O/R X-pipe, so I'm assuming the latter two are related to the O2 sensors...all help appreciated, thanks
RE: My car going to sh*t???
ORIGINAL: Myfetang
yeah, that'll definitely be the first thing I do...the burning oil is a huge concern though
Yep, piston rings was my guess...unfortunately...I'm color blind so I can't tell what color the smoke is coming from the exhaust, but no smoke from the engine...I did notice some oil right by the drain plug. It was a tiny amount, and never leaked onto the ground...I hope that's all it is. I'm concerned it needs an engine rebuild
yeah if its not smoking to bad and you're not dumping quarts of oil in it every couple hundred miles you might be about to get away with using an oil additive. when my rings go i plan on just buying a whole new shortblock, a 331 to be exact
ORIGINAL: Myfetang
Thanks for help, I'll definitely look into an Oil Additive. Yeah, I guess if the engine does decide to go, then I can look for a 351 W. Thanks for the help Brutal
