Lower intake
Lower intake
I cracked my lower intake by overtightening a bolt today so now I have to replace it and funds are low. So I was planning on useing the old lower intake off my 94. I know the upper is shorter but I don't know all the differentses. I'm planning on useing the 87 top and the 94 bottom. Can anyone tell me if this will work?
RE: Lower intake
How the heck you over torque the bolts??? There is a guide that tells you what to torque them to and in what sequence. Did you maybe not have the lower intake sitting flush, maybe a little cocked?
RE: Lower intake
no it wasn't really a bolt but the heat sensor that taps into the lower intake . it was turning easy the next thing I know is (CRACK) .I was like ( oh my god) then I had to go change underwear. Well atleast I have two extra lower intakes to work with. Thank god it only happend with a stock intake. Do I ned guid pins when installing the intake?
09-01-2015 08:16 PM
