intake hose
intake hose
ive got the c&l 76mm intake hose and MAF. this set up still uses the factory air box though. i was wandering if there is a cheap kit or pipe with filter that i can use to attach to the 76mm MAF and run a cone filter in the fender well instead of using the factory air box? is it worth changing?
RE: intake hose
Get an aftermarket cold air for it with a K&N
BBK makes some good setups and the filter tucks into the fender.... Not as easy to change and clean as stock induction but better
As for cheap kits... How cheap are you talkin? You know you get what you pay for with most aftermarket parts, dont go to cheap
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
