What octane fuel do you run?
RE: What octane fuel do you run?
ORIGINAL: lookinforastang
dont got a timing light
shes pretty responsive so i would assume its been bumped a little
Do you have any friends with a timing light, etc.? If not, go to autozone and you can get one for like $30 bucks. Its definetly a good investment.
ORIGINAL: turbostang21
does anyone run E85
does anyone run E85
ORIGINAL: MadMan@TheWheel
Some words of advice. Your motor is supposed to be specified for use with E-85 you are not supposed to run that in any motor not designed to run it.
^^i noticed a few pumps in pa/nj that have a sticker on them that says something like "contains up to 10 % ethanol". so i guess that took care of my biggest worry...which was not knowing if i used it or not. i will not use that crap in my stang
Well, I was running 91, as my timing is set at 14 degrees. Then two weeks ago, I tried some 89 just for the hell of it, and the car runs the same or better, with no pinging. I may try 87 one day.
