Throttle Body
Throttle Body
i was looking into building an engine over the course of the net year and i was wondering what would be the best throttle body to have in it. its going to be the ford racing gt-40 302 i was thining the bbk 65 mm throtle body but does anyone have any suggestions?
RE: Throttle Body
bbk 70 mm is what i have and my stang runs sweet, it revs sooo freakin fast and i have senn 70 mm put on a lke bone stock stang and it definetly isnt to big, GO FOR THE 70!!!!!!!!!!!!!!!
RE: Throttle Body
Well you'll have to add bigger injectors, my guess would be 24 lb.
But regardless, if your planning on modding a lot, bigger injectors are always good...
But I'd say 70mm if you plan on modding it pretty well, if not i'd go 65mm. I bet you could keep stock injectors with the 65 too.
RE: Throttle Body
Righto, 70mm is pushing new injectors, especially if you're going to be using (EFI) big MAS and intake or (CARB) larger cfm induction. So it should be based on your final goal for the engine/car. If your going to go all out, why not change the injectors and fuel pump and go with a large induction system. But if you want to keep it a little more mild and have good power but not have to go through the money and time of the fueling system, then go with the 65mm.
RE: Throttle Body
ORIGINAL: vfast
well I would first look at all your pieces your putting in your engine as the t/b would be one of the last things to concider
RE: Throttle Body
ORIGINAL: mdvaldosta
you know if the leading elbow / tb maker in the industry tells you that, then you better listen!
oh yea, and do it because I said so too kk? hell even my daddy vfast said it!
