help snmoking brakes
RE: help snmoking brakes
ORIGINAL: dj1203
its the passneger side rear. its a disc brake.... there is some fluid leaking from it... i am guessing its from the caliper.... where would i find a good relacement caliper?
If you removed the lines, did your brakes, put the lines back on, when you bled the brakes, the caliper would have come out, leaked from the line to caliper connection, and not been 'sucked' back in. When you replaced the pads, did the piston go back in the caliper easily? If not, it'll definitely need a new caliper.
Also - check your rotor if you drove it around as you may have warped it.
- Jeff
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
