window motor instalation
RE: window motor instalation
the window motor is attached to the window regulator on the door frame and it comes off with 3 screws and a clip, when you remove it check to make sure its not the bushings, press the switch and if the drive turns a lil bit then its the bushings(available at 50resto), if it doesnt then its the motor, and the motor should be cool when your using it, if its hot then its no good. good luck
hey 7up, mine does something like that...on both driver's side windows, the motor will "stutter" and wont roll the window up on its own unless i grab it and pull it as it goes up...would that be the bushings? there's still motor left because it will go up when i pull it. but the odd thing is that its both driver's windows...maybe just a coincidence?
ORIGINAL: chath_brick
no it means ur car has AIDS
ORIGINAL: BascoSauce
LOL!!!
Chath_Brick ... I agree ^ grease all the moving parts and then try it before you take the motor out to check the bushings, if that doesnt help, check bushings and if there shot get new motors. Have you tested the switches? maybe an intermittent short to that side?
no guys, my car doesnt have AIDS ...is that the best you could come up with? i'll try the grease trick, i never thought of that. it might be the switches though, its kind of odd that the same thing would happen on the same side of the car with two seperate windows.
well on my '90 all four windows would go up and down with the drivers side switch but not with the other 3 switches, come to find out the drivers side switch was bad and wasn't completeing the circuit to the other switches... who woulda thought huh?
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
HorsePower99
08-26-2015 11:29 PM
