MSD ignition - Page 2 - MustangForums.com
MSD ignition
Old 08-08-2006, 11:35 PM
jzgt
Default RE: MSD ignition
Sure...I'm not saying he should just open the gap up as wide as it'll go...
It's a trial and error thing...Really best done on a dyno.
As far as the boost levels you may see there are many factors such as restrictions before and after the blower. Where are you getting your signal?
- Jeff
Edit: I forgot to mention I have mine gapped at .035 (Autolite 3924's) with no problems. What comprises the rest of your motor?
jzgt is offline
Old 08-09-2006, 11:27 AM
bouchermb
Not sure how much gap I'm running now, but I did just have it dyno'd. I should have had it done then. I have split fire plugs and gapped them according to stock 5.0 specs.
You're right in that it's REALLY tight under the hood and I couldn't figure out a palce to mount it. It would probably have to be somewhere in the car. May be the passenger side foot well. I'm getting about the higher boost reading right as I goose throttle, then it backs off a little.
The rest of my mads are TF Street upper/lower intake, 73 MM MAf, 70 MM TB, BBK 1 5/8 inch equal length headers, full 3 inch exhaust and Borla mufflers, Mass Air Conversion, pulleys, MSD Blaster coil, 9mm motorsport wires, fluidyne aluminum radiator, 30 lb. inj., 190 lph FP, and I some other stuff that I don't think is relevant.
bouchermb is offline
bradleyb
11-27-2015 08:50 PM
firehorse02
11-16-2015 12:28 PM
bradleyb
California Regional Chapter
10-01-2015 02:02 AM
jessicarabbit
09-25-2015 01:41 PM
Wombatnation
09-13-2015 10:16 PM
Quick Reply: MSD ignition
Featured Sponsors
