i need a answer not i would suggest plz
would i need 2 get my car tuned or get a mass air flow for my car changing 19lb injectors to 19lb injectors and i need a answer asap plzzz.
__________________________________________________ ____________________________
1988,5.0,whole exhaust system,75mm trottle body, pulleys, trick flow upper and lower intake
RE: i need a answer not i would suggest plz
If you are changing the injectors you have 2 options.
1. Get the computer tuned for the new injectors.
2. Get a new MAF to trick the EEC into proper afr's
I suggest the maf route, as the stock unit will be a slight restriction to anything needing more then 19lb injectors.
Let us know all the details of what you have now, and what you plan on doing, and we can provide better advice.
jason
jason
I'm confused you swapped 19's for 19's? but yea you'll need to get the MAF recal'd, and reset the 'puter by disconnecting the battery for a few min. I'm still confused though? .........[&:]
If hes changing 19's to 19's why would he have to have it recalibrated? Its the same thing. If your swapping out stockers for stockers no you dont need to be recalibrated, tuned, etc.
Now if you are swappig 19's to 24's than yes you need to have it calibrated but no not a tune.
https://mustangforums.com/m_1781856/...tm.htm#1782168... i think this is what he is talking about.
