Quick Help
RE: NEEED Quick Help
Sounds to me like you are not getting any fire from your plugs. That would be on my check list. Have you done anything to your car recently?
How much gas did you add to your tank? Are you on a hill?
I just put the engine in less than a month back....
I know one of the wires fell on the header and burnt a little.
I don't know where the fuel turn on switch is
and the hold the gas to the floor and crank didn't work either
burnt wire for sure, when the key is in accesory posistion you should hear the fuel pump kick on... if so your getting fuel from it, could be the starter, try hitting it with a hammer as you try to start it... takes two people, most likely wire though
Make sure you are getting fire so we can cross that off the list. It is easy to check. Pull off a plug wire, stick your finger in the hole and get your buddy to turn the engine over.
Curse my slow typing skills!!!!!
