Once I get the money....
Old 08-12-2006, 03:37 PM
All4n
All4n's Avatar
Default Once I get the money....
This is what I am getting. Not wasting any time or money on my current stock motor which has 134k miles on it.
http://www.jegs.com/webapp/wcs/store...tegoryId=10763
Has anyone ever installed a new motor before on their Fox body? How hard would you say it is to do something like this. What else can I expect to be buying to make this fit and run? Thanks for any help I can get.
All4n is offline
Old 08-12-2006, 03:40 PM
randy78045
randy78045's Avatar
Default RE: Once I get the money....
It's not that difficult, but you can do better than the engine you picked out...
randy78045 is offline
Old 08-12-2006, 05:00 PM
MadMan@TheWheel
MadMan@TheWheel's Avatar
^+1000 You can if you are smart about it build a 351W shortblock up with heads and cam and produce a ton of HP within a close price range. You can get the short block in the vicinity of $2500 and heads for $1700-$2000 range and kick some major a** and be far ahead of the game. If you are planning on building serious HP in the future the time to start is now.
My $.02
MadMan@TheWheel is offline
Old 08-12-2006, 06:44 PM
88stangaruu
88stangaruu's Avatar
My $.02
+1
But why you just throwing the 302 out? 134K isnt alot of miles on a 5.0 roller motor. You can still do alot with it. I mean even with that crate, your still going to have to buy, bigger injectors, a new intake, headers and exhaust, Throttle body, CAI, etc. I mean, get some iron GT-40s with a set of shorteis and a Trick Flow intake, some 24* injectors a Trick Flow stg. 1 cam and your still coming out cheaper than that crate engine and about the same power as its making.
Like i said 134K isnt alot on a 302 roller motor, expicially since you would be rebuilding the heads on that motor you have now by getting the GT-40's. Just do a compression test and if it comes out good, then your good to go on that bottom end.
88stangaruu is offline
Old 08-12-2006, 08:46 PM
kennebell92conv
kennebell92conv's Avatar
get a 347 go bigger from dss and afr heads
kennebell92conv is offline
Old 08-12-2006, 09:22 PM
Billymac76
Billymac76's Avatar
look around for remanufactured motors... or CHP and such
Billymac76 is offline
Old 08-12-2006, 10:42 PM
samseed101
samseed101's Avatar
ORIGINAL: All4n
If you are going to buy that, why not spend an extra $300 and buy this setup instead? For $300 extra, you can get an extra 55+ HP and some extra tq. And you get a nice 347 stroker instead
samseed101 is offline
Geo4K
08-20-2013 10:18 AM
HeLLFiRe xx
01-06-2013 09:15 AM
BigDinTexas
Archive - Trades & Freebies
07-25-2010 12:36 PM
nitrous_bob
07-17-2010 08:05 AM
aaronrmrz
04-03-2009 12:00 AM
Quick Reply: Once I get the money....
