What to do with a stock 5.0?
RE: What to do with a stock 5.0?
Get every piece of chassis bracing you can find, then suspension, then brakes. I personally would rather have my car drive good first.
Remember, spinning aint winning.
Mine is still stock and the only thing I might do is exhuast and the 3.73's. I just like the clean stock look that Ford did to them.
Well I did put Ponys on mine, those turbines just don't cut it for me.[:'(]
1. k/n filter
2. sythedic oil
3. under drive pulleys
4. get 3.55 or 3.73 gears
5. 2.5" exhaust
6. upgrade calipers to 73mm
7. 73mm or 76mm maf
8. 65mm throttle body
9. electric fan
10. 100 + amp alt.
11. 185 mr. gasket stat
12. set of 1.7 rocker
13. set of shorty headers
14. mechanical oil pressure gauge
15. 190 lph fuel pump
16. set of drag radials
17. battery in trunk
18 3 core rad
this should help a ton
2. sythedic oil
5. 2.5" exhaust
7. 73mm or 76mm maf
9. electric fan
10. 100 + amp alt.
18 3 core rad
