A/C delete question
RE: A/C delete question
ORIGINAL: HACKGT350
the place you are getting it from should have a the size belt listed in the info
this might help under the info it tells you the size belt well the part number that you can look up and get it
http://www.mustangsunlimited.com/ite...=&CatKey=74-01
ORIGINAL: 88stangaruu
+1.
Dont waste money on pullies. They just clutter the engine bay up IMO.
if your running stock pulley's just buy a belt from the parts store for a non ac car
+1.
i have no Smog or AC and i got the trick flow AC alimination plate that moves your tensioner pully to where your AC should be, then you just remeasure for a new belt with a string, then buy the 5 closest belts to what you need and keep the one that fits and take the rest back.
BTW, my PS is the the stock location. THe bracket i got moves aroudn all that, it was $25 if i remember right.
When your doing AC and Smog deletes, you should always do them at the same time, imo. Makes things much easier and you only have to buy one new belt.
