Smog Pump Delete????'s
The smog pump was removed by the previous owner. He left all the smog pump solenoids in place. Can I remove all the items that I have put and X on and cap the lines?
All this is still on the car with the exception of the charcoal canister.
Also can I remove the smalle white block that has both erg and smog pump lines running through it? It's not on the diagram so I'm assuming that it is just the to organize the line and doen'st "do" anything.
Thanks.
Thanks.
RE: Smog Pump Delete????'s
if the pump isnt there and there are no emissions and your not wanting to just put the pump back on to pass emissions and remove it again, i would say take everything that has to do with the smog pump out. I would leave the EGR alone, if you take it off you risk getting detonation without having the EGR feature removed from your computer.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
