94-95 PVC Valve Help
I can't find it. Is it under the manifold or what? Who has changed theirs and can give me instructions?
I know it's at the back passenger side of the intake manifold but I can't see the metal valve or the two smaller tubes running off of anything.
RE: 94-95 PVC Valve Help
Just changed mine on my 95 GT. It is impossible to see unless you take your hood off. It is slightly to the passenger side of your intake manifold and is plugged into a rubber gromet. There is a roughly 1/2" rubber line that goes to it. If you follow this rubber line from the PCV valve towards the drivers side it will have a T in it. Your gonna have to pull up on the PCV when you have located it by feel, it shouldn't be that hard to get out. Once you've changed it find the hole with your finger and stick the PCV back in it.
good luck
good luck
